Band of Brothers from PLAY.COM : Import Duty and Packing
thestorm
Where are you going to buy it from?
With Play i reckon there is going to be import duty :
http://www.playserver3.com/play247....tle=107423&id=0&adudisc=y&cpage=1&duty=107423
I already got stung twice this week on rare
cds from amazon.com
With this particular order I think I'll order elsewhere as Im
quite sure there will be import duty and knowing play.com the
tin item will be delivered all bashed up and corrugated.
I think i'll get it from cdwow.com :
http://www.cd-wow.com/detail_results_2.php?product_code=2954
What abt you?
Cya,
Shaz
encaser
dvdsoon have it @ £44ish and are regarded as customs friendly.
CDwow is prob' the safest option at a reasonable price and they are quick to remedy bashed stuff and the one I'm also going with.;)
This really has been a war-tastic year for dvds - pack up your troubles
thestorm
£44 sounds pretty good! i hope there's no customs charge.
so... is it widely used like play or ezydvd?
are they reliable?
MonkeyDonkey
I'm probably gonna get R2 from Play, its £44.99.
But I'm still waiting for a bit more info before I order, If I do choose R1 I think cdwow will be getting my dosh.
D
DaveP
Have you got a link? A search fails to find Band of Brothers!
DaveP
T
the badger
I got Die Hard box set from Play without any duty despite the warning- I think it is just a warning that you might have to pay duty but I don't know how often it actually happens
