Bananas in Denon 3801again.
Discussion in 'AV Receivers & Amplifiers' started by Steverol, Jul 1, 2001.
Tags:
  1. Steverol
    Steverol
    I was just looking back to this topic on 2.5.2001 because I am about to try and get theses plastic bungs out so I can get the bananas in.Do you lever the bungs out from the outside or is there a way of pushing the bungs out from the inside? I have tried unscrewing the terminal right off but it only goes so far and I don't want to force it.I have had a bit of a hack at it from the outside without much success. I would appreciate some advice from you guys who have already done this. :confused:
  2. ReTrO
    ReTrO
    Jul 12, 2000
    3,507
    2
    71
    High Wycombe, Bucks, UK
    +59
    You should just be able to ping the caps out from the outside using a stanley knife or similar.
    Rick
  3. Gavin_Hall
    Gavin_Hall
    Apr 18, 2001
    875
    46
    Maidstone, Kent
    +174
    Simply use something very small and sharp and they simply ping out from the outside.
    I used one of those tiny screwdrivers, watch maker size :)
  4. Steverol
    Steverol
    Thanks guys, I've managed to ping them out just like you said. I think I was nervous of causing damage at first but after reading your messages it was quite easy.
  5. Jim Robson
    Jim Robson
    Jul 14, 2000
    245
    Originally from the wonderful Granite City, Aberde
    Atomic/ReTrO?? When did that come about?? It's very 'posh' to have a double-barrelled handle! :rolleyes:
    Regards
    Jim :D
  6. ReTrO
    ReTrO
    Jul 12, 2000
    3,507
    2
    71
    +59
    Jim Robinson?? When did that come about?? It's very 'posh' to have a double-barrelled handle! :rolleyes:
    Regards
    Rick
    ;) :D ;) :D ;)
    I used to use the handle DieAtomic from my Quake playing days, and then moved on to ReTrO after watching The Matrix (opposite of Neo). But on Yahoo someone had already used the retro handle so I had to call myself atomicretro, so it's just to help people ID me.
