Banana Plugs
Discussion in 'AV Receivers & Amplifiers' started by paulw77, Jan 4, 2001.
  1. paulw77
    paulw77
    Nov 18, 2000
    613
    28
    Wigan
    +48
    Are there 2 different sizes of banana plug ?
    The ones I have do not fit my Yamaha DSP-A5 (too big). I have however, seens a review of another Yamaha amp which appears to have the same size binding posts as the A5. The review said these were capable of accepting 4mm banana plugs.
    If these will fit my A5, does any know a good supplier ?
  2. Guest
    The Banana is a standard size (4mm), the only other Banana compatible is the RFA(?) designed to meet Euro standards. Used as an RFA the contact is inside the plug (recessed within the 'bit of kit'); a removeable sheath alloys it to be used as a Banana.
    My last Yammy (2070) wouldn't accept Bananas at all.
    Tschaikowsky:
    Was he the tortured soul who poured out his immortal longings into dignified passages of stately music?
    Or was he an old poof who wrote tunes?
    [This message has been edited by PeteH (edited 07-01-2001).]
  3. Sam
    Sam
    Nov 6, 2000
    329
    Surbiton
    +9
    I didn't think that any recent Yamaha amp accepted bannana plugs...
  4. paulw77
    paulw77
    Nov 18, 2000
    613
    28
    Wigan
    +48
    Thanks for the replies chaps, but....
    If Yammy amps don't take banana plugs, why are there 2 different types of connector (for example on the A5 ?). Why not just use spring clip terminals all round ? What is the hole for ?
    The terminals that I assumed would take banana plugs have a hole in the end (like the bigger binding posts). To attach the speaker cable you unscrew the terminal, insert your cable in the side and screw it back up again.
    The picture in the review of (I think) the Yamaha DSP-AX1 in HCC has the same binding posts as the A5 and the review mentions that it takes banana plugs.
  5. miketango75
    miketango75
    Sep 13, 2000
    176
    +5
    The A5 does not accept bannana plugs. However the AX1 does if you remove the small plastic plugs from the centre of the binding posts.
    Ian.
  6. Guest
    Just how big (internal diameter) are these holes? It sounds from your description as though their presence is simply part of their manufacturing process.
  7. Jeff
    Jeff
    Jul 13, 2000
    5,507
    Basingstoke
    +263
    I have the same holes on my Yamaha RXV995, I thought they were banana plugs, but they are to small at about 2mm diameter. I heard somewhere that you could unscrew them and replace with banana plug types, I haven't tried though.
