I doubt you will notice any drop in audio quality by adding banana plugs. If you are planning on connecting/disconnecting the speakers from the cable regularly, then yes they are worthwhile. If however you will only be wiring the speakers up once and leaving them permanently installed, then I'd say save your money and don't bother with them.
