dogtown
Established Member
I bought some Cambridge Audio ones from Richer Sounds and what utter rubbish, firstly the cable has to go in the side and then you have to drop in a round spacer then tighten the end down, I would of prefered the cable to come in from the rear and be secued by a screw. Secondly the only way of fixing a loose fit it to pry the prong open a little and upon doing this it came out of the plug itself and is now broke!!
Rubbish.
Is it worth spending the extra to get good ones or are they all much of a muchness??
Steve
Rubbish.
Steve
