banana plugs??
Discussion in 'Cables & Switches' started by skanky, Aug 26, 2004.
  1. skanky
    skanky
    Jun 25, 2004
    what are they used for? are they worth the money? and will i be able use them on a uk spec yamaha rx-v450?
    ta.
  2. Ian J
    Ian J
    Aug 6, 2001
    25,528
    +4,906
    They are use to attach speakers cable to speakers and amplifiers. Whilst they are illegal in Europe most manufacturers have just plugged the hole with a plastic plug which is easier to pop out.
    They are useful if you play around with your equipment as they are easier to plug and unplug than constantly unscrewing and screwing back cable onto terminals but probably have no sonic advantages at all.
