banana plugs??
Discussion in 'Cables & Switches' started by skanky, Aug 26, 2004.
  1. skanky
    skanky
    Jun 25, 2004
    32
    what are they used for? are they worth the money? and will i be able use them on a uk spec yamaha rx-v450?
    ta.
  2. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    just for connecting speaker cable to binding post, should be no issue for yam, dont really help quality but great for quick speaker changes! (also used on rear of compatible speakers)
  3. CDphobe
    CDphobe
    Jul 11, 2004
    1,100
    48
    Bolton
    +81
    I'm not normally one to disagree with veterans <g> but I'm not so sure that the Yamaha will accept bananas. If I recall, all Yamaha amps/receivers for the European market have been binding post only (effectively just bare the end of the speaker cable and tighten the clamp down) for a year or so, and the 450 is a current model I think. Something to do with one of those crazy EU regs that some manufacturers have taken to extremes to avoid litigation (touchproof sockets for all "power" connections? - hence also the move to BFAs for Linn, TAG etc).
  4. MarkE19
    MarkE19
    Aug 10, 2002
    17,335
    Rainham Essex
    +2,433
    Most if not all amps/receivers sold in the UK (and rest of the EU for that matter) will have the end of the binding posts covered with a plastic cap. 9 times out of 10 these can be removed with a small screwdriver or perhaps broken away so that banana plugs can be used. I did this with my old Denon 3802 and many others on here have done the same on their amps/receiver. I am not aware of any company that make it too difficault or impossible to remove the end caps.
    Mark.
  5. CDphobe
    CDphobe
    Jul 11, 2004
    1,100
    48
    Bolton
    +81
    Fair point Mark, but the OP was asking what a banana plug is, and what its for - in this instance I woudn't be advising trying to remove the centre caps - just use the binding posts as provided and have done!
    Incidentally, I've never tried, but I've always assumed the "easily removed" doesn't apply similarly to BFAs. Anyone know any different?
  6. skanky
    skanky
    Jun 25, 2004
    32
    thanks for the replies, had a quick look through my instruction manual after reading how UK yamahas wont take banana plugs and yep, says it in the manual too.
    oh well, i guess im not the sort of person who unplugs regularly anyhow.
