banana plugs or bare speaker cable?
Discussion in 'Cables & Switches' started by onefunkypenguin, Dec 19, 2006.
  1. onefunkypenguin
    onefunkypenguin
    May 25, 2006
    1,414
    Glasgow
    +63
    hello, just got new amp, harmon kardon 7500 and it seems to accpet banana plugs for the speaker connections!
    now im a complete noob, so can i just use bare speaker cable or do i need to get some banana plugs???
    its just that when you unscrew the terminal things theres no hole in the middle like there is on back of speaker and on my old denon amp.
    thanks
  2. Badger0-0
    Badger0-0
    May 30, 2005
    20,601
    Spaghetti Junction (really)
    +1,923
    Personally, I don't think it matters that much.
    The advantage with plugs is you can easilly disconnect them, and that's it.
    As long as you have a sound connection, you're OK.
    Oh, I suppose with plugs you're less likely to get a short, but if you're careful, it's not a issue, IMO.
  3. onefunkypenguin
    onefunkypenguin
    May 25, 2006
    1,414
    Glasgow
    +63
    there doesnt appear to be much room once you unscrew the terminal, do i wrap the wire round them and then screw the terminals back on???
  4. Badger0-0
    Badger0-0
    May 30, 2005
    20,601
    +1,923
    Yes :smashin:
  5. onefunkypenguin
    onefunkypenguin
    May 25, 2006
    1,414
    Glasgow
    +63
    all systems are go! just tuned it into the radio just now as i dont have a tv or dvd player til end of week!
    will need to study the manual til i know what im doing so when i get everything its just a simple case of plugging it in and bingo.
    sounds amazing just now though!
    thanks
  6. Badger0-0
    Badger0-0
    May 30, 2005
    20,601
    +1,923
    nice one :smashin:
