Banana plugs - easy to fit?
Discussion in 'Cables & Switches' started by mevetts, Aug 10, 2004.
  1. mevetts
    mevetts
    Oct 31, 2003
    439
    Well that's it really! Are banana plugs easy to connect to cable or is it best to get a 'pro' to do it!
    Cheers,
    Mark.
  2. NaTT
    NaTT
    May 27, 2003
    1,123
    Abbots Langley
    +77
    some need soldering so if you can do that no problem
    most just need screwing onto the end of the cable, so if you can strip back the outer casing back to bare wire and turn a screw driver, no problem again.
  3. MarkE19
    MarkE19
    Aug 10, 2002
    17,312
    Rainham Essex
    +2,425
    and some are crimped. So unless you pay the dosh for the correct crimping tool, then they are impossible to fit!
    As you can see it all depends on the type of banana plugs you buy. On high(er) end kit it will probably be worth getting them proffessionally fitted with silver solder or good crimp joints. The screw fit plugs are ok, but they will work loose and need to be checked from time to time.
    Mark.
