Banana plugs dont fit in speaker nor in receiver
Discussion in 'AV Receivers & Amplifiers' started by metallon, Jun 16, 2017.
Tags:
  1. metallon
    metallon
    May 14, 2017
    7
    Berlin
    Dear HiFi Experts,
    I just got some really nice Triangle Banana Plugs with my Triangle Elara LN 07 but they dont fit in the speakers and neither in the Denon 4300.
    What am I doing wrong :) ?
  2. metallon
    metallon
    May 14, 2017
    7
    Berlin
    I have taken out the little plastic head of the receiver input (you can see it on the photo at the side) and the speaker screw connector is screwed off to show you where the plug "should" fit in.
  3. Rambles
    Rambles
    Jul 14, 2004
    10,528
    167
    UK
    +2,205
    Do they fit if you apply a very gentle bit of pressure? Some plugs actually close in a little as they slide into the connector. Obviously don't force it and break anything though!
  4. metallon
    metallon
    May 14, 2017
    7
    Berlin
    Hi punctilio,
    Thanks for your reply. I dont see them fitting in. I have applied lots of pressure.
    I have undone the speaker connector screw just so I can really push and see but it doesnt seem to work. I thought it would be a standard measurement :)
  5. metallon
    metallon
    May 14, 2017
    7
    Berlin
    Actually I really pushed hard and the thing went it but I cant do that with the receiver. Should I squeeze them together a bit?
  6. Rambles
    Rambles
    Jul 14, 2004
    10,528
    167
    UK
    +2,205
    Worth a try, as they are brand new, they may be a bit stiff. Should all be a standard size.
  7. scarty16
    scarty16
    Jul 1, 2003
    1,681
    +456
    push harder, pretend it is the girlfriend and not the wife :)
    • Funny Funny x 9
    • Like Like x 4
    • List
  8. dodge586
    dodge586
    Mar 31, 2007
    126
    +9
    Don't push any harder on the receiver!!! There is an inner lug you have to remove that isn't obvious! I had the same thing and googled it and found this out. The solution was to bend a paperclip into a hook/catch insert it into the hole and then pull outwards this will pull out a smaller inner piece of plastic.
    I think this was the video that made it obvious:
    Tip - Banana Plugs into AV Amp Speaker Wire...
    Why it's like this I don't know!!
  9. Rambles
    Rambles
    Jul 14, 2004
    10,528
    167
    UK
    +2,205
    He's taken those out (post 2).
  10. Rodders53
    Rodders53
    Dec 8, 2007
    5,352
    Bedford
    +971
    Force is required. New plugs and better quality ones are more resistant. I find that twisting/rotating the plug while pushing in can often make it slightly easier.
    The electrical connection is made on those four sprung fingers, so they need to be a tight fit!
    You may need an accomplice to prevent the AVR from moving, if you can't get an arm round/over to do it on your own.
  11. Deleted member 598831
    Looks like a bit in the speakers connection can come out also?
  12. fayeanddavid
    fayeanddavid
    Sep 23, 2009
    5,728
    Bearsted Kent
    +2,051
    Some nonsense from an EU directive relevant to people wanting to stick the mains supply in them......
    We are best out of it......
    Grumble grumble, raa, raaa, bloody European bureaucrats, raa!!!
  13. jfinnie
    jfinnie
    Oct 1, 2004
    4,581
    Norwich
    +1,933
    Other way round; the problem is people sticking the 4mm plugs in the crappily designed unshuttered euro mains sockets. So by blocking the sockets on receivers it theoretically makes the plugs redundant in the market.
    How about they legislate to not have death traps fastened to the walls instead? GRRRRRR
  14. fayeanddavid
    fayeanddavid
    Sep 23, 2009
    5,728
    Bearsted Kent
    +2,051
    Chicken and egg I guess............ oh, and stupid people
  15. Rambles
    Rambles
    Jul 14, 2004
    10,528
    167
    UK
    +2,205
    Having to remove some plastic plugs from speaker terminals is okay with me if it reduces the risks of house fires. Sometimes more legislation can be a good thing.
  16. fayeanddavid
    fayeanddavid
    Sep 23, 2009
    5,728
    Bearsted Kent
    +2,051
    It's not about the legislation it's more about the stupidity that someone would/could/may/might plug speaker terminals (clearly marked as such) into the mains socket on the wall!!!
  17. Rambles
    Rambles
    Jul 14, 2004
    10,528
    167
    UK
    +2,205
    Well, maybe, but it would be nice to prevent house fires, even if caused by stupid people.
  18. gbjbaanb
    gbjbaanb
    Dec 30, 2008
    705
    UK
    +335
    I've seen a video (on the internet, obviously) of some idiot wrapping his old man in tinfoil and sticking it into the mains. (there was a bang, lights went out and a bit of screaming). Never underestimate stupidity. Still, proper power plugs like what we have in good old Blighty are what the euros should have, ones with an earth plug that you have to stick in to get the internal covers on the business sockets to slide out of the way. (I'm very impressed with the thought that went into the British plug spec, not like those Euro ones that are just 2 holes and a shrug)
  19. gibbsy
    gibbsy
    May 17, 2007
    15,269
    3
    Sitting next to an aquarium
    +8,972
    Hmm, this thread has taken an interesting and unexepected turn.:D
    I've found no problem in pulling out the inserts on the back of my Denon using the wife's finger nails. I certainly get a better connection using banana plugs than trying to tighten the binding posts with arthritic fingers. On a 6200 they are so close together.
    I've kept the inserts in a plastic bag just in case an European with an odd fetish wishes to buy my 6200 in the future.:thumbsup:
  20. fayeanddavid
    fayeanddavid
    Sep 23, 2009
    5,728
    Bearsted Kent
    +2,051
    And where do you keep the wife's fingernails during the interim???:D
  21. preuser3
    preuser3
    Feb 24, 2015
    327
    USA
    +56
    Maybe not using Mono-price ? :rotfl:
  22. dante01
    dante01
    Mar 5, 2009
    46,852
    +11,312
    Who left your door open?
    Monoprice are a USA concern and do not trade in the UK. Besides which, why monoprice when there are plenty of other affordable alternatives readilly accessible to customers in the UK.
  23. scarty16
    scarty16
    Jul 1, 2003
    1,681
    +456
    From Banana Plugs to just Bananas in 24 posts.
    • Like Like x 2
    • Agree Agree x 1
    • List
  24. fayeanddavid
    fayeanddavid
    Sep 23, 2009
    5,728
    Bearsted Kent
    +2,051
    Thanks for the irrelevant input, all a bit unnecessary...........!
  25. fayeanddavid
    fayeanddavid
    Sep 23, 2009
    5,728
    Bearsted Kent
    +2,051
    What.................!!! ????
  26. Skull n Bones
    Skull n Bones
    Aug 23, 2013
    1,825
    116
    U.K.
    +921
