I have Klipsch Reference speakers and binding posts seemed not very good to connect bare wire.
So I tried banana plugs where you have two screws to fasten the wire.
Connections seemed good and I used them about 3 months.
Sound was ok but something was kind of lacking. So finally I tried to remove
the banana plugs to see if it would make any difference.
To connect bare wire I really took care to connect tightly to the speaker
binding posts. The difference was huge like I would of installed new speakers.
So if you plan using banana plugs I recommend against them.
If you have them installed and something seems out of place in the sound try to remove them and see
if in your system you hear any differences.
