Banana plugs are sending me bananas can you help????
Discussion in 'Home Cinema Speakers' started by Jasoon, Feb 21, 2002.
  1. Jasoon
    Jasoon
    Anyone seen this type of banana plugs before?
    I’m not sure how to fit a cable in it i.e. solder it or what
    Can someone shed some light on the best way to terminate them.
    Jason....
  2. ReTrO
    ReTrO
    Jul 12, 2000
    3,507
    2
    71
    High Wycombe, Bucks, UK
    +59
    Jasoon:
    That looks like a standard screw type banana plug, with the pin part taken out, for some reason.
    Very easy to use. Screw the pin part into the end it fits and then put your bare cable through the hole and tighten on the nut end.
  3. DodgeTheViper
    DodgeTheViper
    Oct 23, 2001
    19,679
    Inbetween Upgrades !
    +8,108
    It looks like an IXOS plug with the little bar missing out of the hole.
    Kev
  4. lynx
    lynx
    Jan 20, 2002
    4,652
    It always rains.
    +302
    £0.86p from CPC by any chance? :D
