Banana plugs and pioneer av receiver?
Discussion in 'AV Receivers & Amplifiers' started by MartinGH1369, Feb 23, 2014.
Tags:
  1. MartinGH1369
    MartinGH1369
    Jan 8, 2014
    453
    Ashford, Kent, England.
    +66
    Can anyone tell me if they use banana plugs with their pioneer amp please?
    I tried to fit mine this morning but they don't seem to fit, do I need to push harder?
    Any help would be appreciated!
  2. mtenga
    mtenga
    Jan 27, 2013
    8,057
    3
    Beckenham
    +2,050
    There is probably little circular rubber bungs in the posts. Usually you can remove them with your thumbnail or a paper clip. Should be ok then.
  3. MartinGH1369
    MartinGH1369
    Jan 8, 2014
    453
    +66
    I did notice those, I didn't want to break anything though.
    Thank you mtenga.
