Banana Plug Wall Sockets
Discussion in 'Home Cinema Speakers' started by pcpaz, Jan 28, 2003.
  1. pcpaz
    pcpaz
    It is possible to get these that either fix to the wall or integrate directly into skirting boards?
  2. richkeys
    richkeys
    Jan 16, 2003
    19
    London UK
    Yopu'll find some
    HERE
    good luck
  3. pcpaz
    pcpaz
    That was quick!! Thanks.
    They are currently out of stock with back orders, MMMmmmm, do maplin do them, I have searched their site but all I could find was the plugs?
    Also is a 4mm plug usually sufficient for a decent quality speaker cable?
  4. Babylon
    Babylon
    Sep 24, 2002
    105
    http://www.sheppeyscum.com
    +6
    Funny,but people go on about buying good cable at 5 10 15 quid a metre,and then go and solder them to cheap looking tat like that,don't get it.
  5. richkeys
    richkeys
    Jan 16, 2003
    19
    London UK
    I would try emailing letsautomate, see if they can give you a date for delivery... I can't think of antwhere else, but will continue looking
  6. Ian J
    Ian J
    Aug 6, 2001
    25,528
    +4,906
    There's a chap on Ebay that has them permanently on sale there
  7. ReTrO
    ReTrO
    Jul 12, 2000
    3,498
    2
    71
    High Wycombe, Bucks, UK
    +59
    Go direct to the speakers if you can. Adding extra joins in wall plates will just degrade the signal quality.
  8. Flimber
    Flimber
    Sep 22, 2002
    13,364
    Yorkshire
    +4,477
    77p + VAT at ARD but OOS currently.
    Mike.
  9. JohnS
    JohnS
    Oct 31, 2000
    2,580
    71
    Herne Bay, Kent
    +33
  10. tollan
    tollan
    Oct 13, 2002
  11. pcpaz
    pcpaz
  12. pcpaz
    pcpaz
    Anyone got any views on the above terminals, I intend fix them to my new skirting.
