Banana Plug/AirLoc
Discussion in 'Cables & Switches' started by danb, Apr 6, 2005.
  1. danb
    danb
    I have an AX5AI and was just wondering, do banana plugs actually go in the hole where the cable goes in or do they go in the middle of the speaker connection?
  2. Wannabe-THX
    Wannabe-THX
    Apr 7, 2004
    233
    On the speaker posts you should find a little black cover plastic at the end. Not where the cable goes.
    This is where they go.
    Fish
