Banana,bfa plugs for 2x 6.0 mm² speaker cable
hifinutt
as i mentioned somewhere else . i use chord bfa cables [ which can be used with arcam or any . these take 6mm and thats what i use . i have many other makes of plug too but these are great for arcam
they are easy to fit with screw fitting
gasolin
Cable received, very easy to strip, perfect fit in the audioquest 100 s bfa plugs soundtest is in 10 min or after my cup of coffee
gasolin
Finally got to connect it
Theres a difference in the bass, to my surprise it's more light footed (not to much bass, mabye cleaner,less bloted bass ? The perception of the bass is that it's still deep) which gives it some sort of clarity in the midrange and highs, i don't find it bright sound and Moreno J mix sounds mabye better in the bass without sounding bloated
Super easy to strip
Can easily recommend Sommer Cable SC-Meridian SP260 it's a very balanced sounding cable
Samsung S95B QD-OLED Review - A Quantum Leap for OLED!
