rccarguy2
Some say there is a difference between think and thicker cable
Some say there isn't but i know some of the more experienced say there is and there is indeed lower resistance thick vs think cable
I personally want some beefy cable, not just 2.5 mm² because i have that, im not going crazy in cable, the cable from thomann is less than 6 euros pr meter (i need 2x4 meter but ordering 9 meter not to have a cable just about long enough if it's not 8 meter or more (or 2x4meter) )
Problem is with som plugs when you tighten it, you often can't use the cover and can't tighten it more so theres enough space for the cover
Same price for the plugs as the cable or less, im not going cracy in price just because i what more speaker cable options
There is, if you use 1mm cable or bell wire, but too thick causes inductance.
