Ball park, how many DVDs per 10gb ?
Discussion in 'Desktop & Laptop Computers Forum' started by Andyuk911, Feb 28, 2005.
  1. Andyuk911
    Andyuk911
    Sep 11, 2004
    427
    +11
    I seem to have 100 DVDs, so how many do people leave on the hard drive ?
    Also, what is the typical need per DVD ? How many would use upto 10gb
  2. Steve Bate
    Steve Bate
    Nov 10, 2002
    680
    Tarporley
    +11
    It depends on how you rip them, if you strip out extras and compress then you'll get more. For reference I strip out all extras and additional languages and have no compression and typically use about 5Gb per disc (up to 7Gb for Films like LOTR)
    Steve
  3. Andyuk911
    Andyuk911
    Sep 11, 2004
    427
    +11
    thanks Steve
  4. Werner
    Werner
    A straight rip on your run of the mill films should be about 4gb. Once your remove the extra fluff it is often 2.5-3.5gb of actual film content.
    If you leave it at that, I would budget on 3dvd's /10gb of space.
    You can, of course, recompress down to about 1gb/dvd (not best compression, but a good trade-off between PQ and size) but this takes extra time. Hard drives are cheap nowdays :)
    Taking Steve's experience and my own into account, you could say 2-3 dvd's/10gb of space.
  5. mjn
    mjn
    May 24, 2001
    24,574
    Herts, England
    +13,389
    i've been getting about 4-5gb per film, thats just the film itself and a 5.1 soundtrack.
  6. drummerjohn
    drummerjohn
    Sep 2, 2001
    2,497
    South Derbyshire
    +205
    Same as mjn - 4-5Gb with just title and 5.1
  7. inzaman
    inzaman
    Dec 16, 2002
    8,018
    Derby
    +1,082
    I too also get about 4-5 gig per movie, this includes end credits cut etc and just 5.1 soundtrack.
  8. Andyuk911
    Andyuk911
    Sep 11, 2004
    427
    +11
    One little other question, what software do you guys use to transfer to the hard drive and have you found any that are easy and fast, or does the dvd drive just determine the speed ?
  9. Steve Bate
    Steve Bate
    Nov 10, 2002
    680
    Tarporley
    +11
    DVDShrink is very easy to use, the speed will depend on your DVD Drive. Mines 16X and it doesn't take that long, I've just had to re-rip 50 DVD's due to a drive failure and it wasn't that onerous, just press the button and go do something else... come back in 5 mins or so and start again.
    Steve
  10. Werner
    Werner
    my vote goes for dvd decrypter for a straight 1:1 onto the hdd.
    If you want to strip out audio channels etc then I would recommend dvdshrink for ease of use.
    I am sure some of the other guys/gals may suggest better alternatives...these things all do a similar job so it boils down to how comfy you feel with the software. :)
  11. mephistopheles
    mephistopheles
    I also use DVD Decrypter (in IFO mode with direct stream copy enabled and choose what to keep/discard).
    I currently have 20 HDD backups on one of my drives, mostly just the MPEG2 video + AC3 audio + subtitles and they occupy 86.9 GB, which is an average of 4.345GB/movie.
  12. inzaman
    inzaman
    Dec 16, 2002
    8,018
    Derby
    +1,082
    I too use dvdshrink, havent tried decrypter but shrink is so easy to use and easy to cut off the end credits etc, this can save about 300mb alone.
  13. Andyuk911
    Andyuk911
    Sep 11, 2004
    427
    +11
    I loaded DVDShrink, v3.2, copied to Disk,..but it took about 1.5 hours!
  14. Andyuk911
    Andyuk911
    Sep 11, 2004
    427
    +11
    Using backup option 1,420 Kb/sec - have I answered my own question ? :suicide:
  15. inzaman
    inzaman
    Dec 16, 2002
    8,018
    Derby
    +1,082
    Yes it should be up in the 11,000 kb/sec,
