Ball joint projector bracelet
Discussion in 'Projectors, Screens & Video Processors' started by dazap, Sep 3, 2017.
  1. dazap
    dazap
    Oct 21, 2004
    1,026
    shrewsbury
    +131
    Is there such a thing as a ball joint projector bracelet.
    This is because I have a slanting ceiling and just can't seem to get it spot on
    Thsnks
  2. paulr2006
    paulr2006
    Jun 30, 2007
    9,535
    2
    Nottinghamshire
    +2,508
    I take it you mean a ball joint bracket? If so yes there are lots of them, take a look on Amazon. Even the types without a ball joint can usually move to accommodate a sloping ceiling.
  3. Shimrod
    Shimrod
    Dec 13, 2007
    346
    28
    +79
    Vogel do a bracket with a ball joint - it is a universal mount that fastens to either a wall or ceiling bracket. You can find the mount instructions showing the fittings here: EPW 6565 Projector Wall Mount
    I ave the wall mount version - it has still been a challenge getting my projector aligned though. There is a little movement after the ball joint is tightened up, so you need to allow for that when setting the final position. Other brackets may have better adjustment.
  4. dazap
    dazap
    Oct 21, 2004
    1,026
    shrewsbury
    +131
    Thanks guys just ordered one
