Balancing speakers
Discussion in 'Home Cinema Speakers' started by villaceltic, Jul 9, 2003.
  1. villaceltic
    villaceltic
    May 22, 2003
    84
    Nantwich, UK
    (I know I posted this on amps and receivers previously but got no responses - impatient I know but it's really annoying me now)
    I'm using an SPLM to try to balance all 6 of my speakers. From following advice from related threads I've turned my amp up to 0db and my SPLM to slow, C and set it to 80db. I then test each speaker in turn and turn the volume up/down to get approx 85db from each speaker.
    However, and this appears to be the problem, if I cycle through the speakers again they are 'off' the level I've just set them to.
    So
    Is the amp resetting these to it's own idea of speaker balance (my surround left always comes back louder than it was, my rear and surround right quieter). I did, prior to having the SPLM, try to balance using the distance from each speaker to listening position that the amp has as a setup option.
    Also when I check the speaker set up on the sound menu it seems to keep resetting my mains to large (I have Kef KHT's so set to small)
    The result is that when playing anything I'm always wandering round listening to each surround to see if there is any sound coming through.
    Any ideas?
    Macca
    :confused:
  2. Jase
    Jase
    Mar 16, 2001
    9,535
    UK
    +933
    Do you have to memorise the settings at all with a key press? Might be worth doublechecking. If it keeps losing the settings then it's possible it might have a fault (hopefully not the case).
  3. pwiles1968
    pwiles1968
    May 15, 2003
    773
    Leicestershire - England
    +10
    Do you have the sub woofer setting turned ON If not your mains have to be large, the system may be reverting to a previous setting because it does not like the idea of everything being small. Just an Idea.
  4. Mitch2000
    Mitch2000
    Dec 28, 2001
    158
    16
    Kent
    Are you setting the channel level correctly? Its not the volume you need to adjust for each speaker it is the level (range -10 to +10 db). Its shown on page 50 of your manual.
  5. villaceltic
    villaceltic
    May 22, 2003
    84
    Nantwich, UK
    Mitch2000,
    Well done - you're quite right I was indeed only changing the volume and not the levels! Thanks.
    I've also found out about using the memory guard which should protect these levels when set and hopefully will stop the amp reverting to 'both' rather than recognising that a sub is there.
    Thanks again - I will endeavour to read the manual fully next time
    Macca
