balanced solder connections
Discussion in 'Home Cinema Building DIY' started by CogPaul, Aug 7, 2003.
  1. CogPaul
    CogPaul
    I am getting one of our technicians at work to put XLR's on some silver cable I had going spare for me. It appears that there is some debate over grounding wiring for balanced and true balanced designs. I have been told to ground only at the source end of the interconnect for a true balanced design?
    Anyone with experience of creating XLR interconnects care to comment on grounding at one vs grounding at both ends?
    many thanks
    Paul
  2. ReTrO
    ReTrO
    Jul 12, 2000
    3,507
    2
    71
    High Wycombe, Bucks, UK
    +59
    Sounds right to me, not ever used them so not actual hands-on knowledge. It's what I do with my unbalanced phonos though.
    What plugs are you going to use? The Neutrik ones seem to be the best to me, very easy to get hold of also, from Maplin etc.
  3. fufna
    fufna
    Neutrik are the only way to go for XLR connections
    Used in all professional studios, very robust and secure connection
  4. CogPaul
    CogPaul
    Thanks Retro - I will tell him to ground at the source end only.
    I am using Neutriks - seemed very popular, reasonably priced and I couldn't seem to find an online supplier of switchcraft xlr's for me to compare prices.
