Balanced outputs
Discussion in 'Blu-ray & DVD Players & Recorders' started by stun, Jan 7, 2004.
  1. stun
    stun
    I'm using a BNC to RGB phono for video, but what is the best interconnect for audio. The sd9500 has balanced outputs, but the 3802 only has phono L & R... Should I try and find a balanced out to phono or ignore the balanced outputs and just use phono left and right?:confused:
  2. ailean
    ailean
    Balanced adds nothing unless both ends are balanced connectors.
  3. stun
    stun
    Thanks ailean, :)
    That's what I sort of thought. Oh well back to some decent phonos...
