Balanced or Unballanced ?
Discussion in 'AV Receivers & Amplifiers' started by petrolhead, Jan 12, 2003.
  1. petrolhead
    petrolhead
    Mar 29, 2002
    4,910
    87
    Newcastle
    +125
    What does this mean when refered to amp?
  2. 7ThGuest
    7ThGuest
    Totally unbalanced in my opinion :D
    Suprised no-one knows anything about this??
    7ThGuest
  3. bob1
    bob1
    Nov 7, 2002
    4,467
    Sheffield
    +133
    put a beer mat under one of the feet:D
  4. mjn
    mjn
    May 24, 2001
    23,931
    Herts, England
    +12,494
    the inputs can be either unbalanced, normal phono connection, or balanced, using XLR connection. Do a search, there is VERY good description on here. I think it even has diagrams as to how it works.
    Its to do with using an in phase and out of phase ground.
  5. daninthemix
    daninthemix
    If you're talking connections between kit - Balanced means the signal is sent normally down one pin, and inverted and sent down the other. The receiving device then adds (or subtracts - forget which!) the two signals. The idea being that any interference that is picked up between the two devices gets cancelled out in the subtraction/addition process...
    A far more detailed and accurate description can be got here:
    I use XLR between my CD player an amp, and aside from an apparently 'quieter' background, the actual sound level seems to be a quite a bit louder than when I tried a single-ended interconnect.
  6. petrolhead
    petrolhead
    Mar 29, 2002
    4,910
    87
    Newcastle
    +125
    Thanks for that
  7. Nic Rhodes
    Nic Rhodes
    Mar 23, 2001
    17,152
    Cumbria
    +1,276
    Best descriptions are posts and articles on Tag web site
