Badr 4(26.0e) on Motorised Dish
Discussion in 'Satellite TV, Sky TV & FreeSat' started by cemist, Jan 11, 2012.
  1. cemist
    cemist
    Dec 22, 2004
    92
    +5
    Just installed a motorised system comprising the following,
    Installation area - Anglesey.
    Technomate TM5402 receiver
    Technomate 80cm Dish
    Technomate TM-2600 Super motor
    I can get the majority of the satellites using USALS, but the puzzling one is Badr 4. On Badr 4 frequency 12226H 27500(Bahrain TV etc) i can get a good signal, however when i try 12182H 16200 there is not a good signal.
    If i nudge the dish once to the east using disecq 1.2 move fine then 12182H channel signal is good but then 12226H is bad and needs a nudge to the west, in essence i cannot have good signals on both frequencies. Anyone have an idea what could be the cause.
  2. cemist
    cemist
    Dec 22, 2004
    92
    +5
    Just tried adjusting my longitude using USALS by 0.1 degree to the west and now i have a good signal on all the channels i mentioned above. Can't get anything from the MBC channels though.
  3. pedro2000uk
    pedro2000uk
    Feb 20, 2009
    5,632
    Cheshire
    +1,072
    What Quality numbers are you getting on Dubai One / BBC World/ Kuwait 2/ Bahrain 55/ EBS. & any 7w?
    You've done well with an TM 80 on Anglesey to get Badr- the TM5402HD will have helped there - very sensitive tuners- we usually use 88 or larger there to give some rain margins.
  4. cemist
    cemist
    Dec 22, 2004
    92
    +5
    Thanks pedro, i've been reading a lot of your posts on here and they are interesting and helpful.
    The first satellite that i can get is 16e, anything further west is blocked by a building. I am going to install the dish higher up which will hopefully allow acces to further satellites.
    Longitude : 4.4W 53.3N
    Signal Quality:
    11938 V 27500 49%
    11958 H 27500 53%
    11977 V 27500 - No Lock
    11996 H 27500 - No Lock
    12015 V 27500 48%
    12034 H 27500 - No Lock
    12054 V 27500 - No Lock
    12073 H 27500 - No Lock
    12092 V 27500 48%
    12182 H 16200 48%
    12226 H 27500 52%
    12245 V 27500 53% Only if moved west, then other frequencies won't lock.
    I can't get Tring on 16e to lock either. Have just bought an Inverto Black Lnb but not installed yet, would this improve my signals?. The current Lnb is Technomate TM-1 Super. Also the position of current LNB in collar is as near to the dish as possible, when further back the signals for badr 4 are poor.
  5. pedro2000uk
    pedro2000uk
    Feb 20, 2009
    5,632
    Cheshire
    +1,072
    If you could modify the LNB holder & feed arm so it can all move nearer to the dish face by 5-10mm then re focus- used to do that a lot but the Black Ultra's long neck should do that anyway [not always].
    Are you using the on screen motor control - [3rd button up from bottom right on remote].
    I would have thought you'd be OK on 16e- check your arc ...what is it btw.. what sats.
    moving around Badr 4 is normal on smaller dishes - you can add a new sat or 2 just for that so have 2 or 3 positions.
    the MBC movie channels are the main ones to get & those I listed.
  6. cemist
    cemist
    Dec 22, 2004
    92
    +5
    Will try the Inverto Black Ultra soon.
    Yes.
    I can get 16e(not all channels), the strong sats from 19.2 to 45e work well with hellassat 83% quality. Will check arc when i move the dish higher for more sats. Maybe i may need a bigger dish to get 16e and 26e properly.
    Ok.
    Thanks.
  7. pedro2000uk
    pedro2000uk
    Feb 20, 2009
    5,632
    Cheshire
    +1,072
    Could you measure the reflector face - width x height minus any raised area of the rim.
    it might be a bit under an 80 too
  8. cemist
    cemist
    Dec 22, 2004
    92
    +5
    The dish is approx: 73cm W x 78cm H.
  9. Ghostleader
    Ghostleader
    Nov 21, 2009
    2,695
    Glasgow'ish!
    +399
    Thats actually not to bad, mine is 80 cm tall & 74 cm wide.
  10. pedro2000uk
    pedro2000uk
    Feb 20, 2009
    5,632
    Cheshire
    +1,072
    so you really have done well :smashin:- that is just 73cm by the offset measure or 75.5cm by the area measure -
