Bad Sky reception on second TV
Discussion in 'Sky Digital TV Forum' started by stuartjprice, Mar 16, 2005.
  1. stuartjprice
    stuartjprice
    Managed, at last, to hook up my second Tv - Lcd to Sky. (Trying to tune an NTSC LCD!!, so now have PAL) All connected Via Coaxial. It looks like ordinary Coaxial. The images I receive from the terrestrial channels are great (must be picking up from the Coaxial as I don't have a seperate ariel for this, I can see the top of the Crystal Palace mast from my lounge window, so perhaps this is why!)
    However, the sky signal is very weak even though I have a digital bypass/booster in the loft, all powered from the 9V sky box RF2.
    Does anyone know why the signal would be weak?
    Thanks!
  2. Nick_UK
    Nick_UK
    Nov 13, 2004
    9,748
    103
    +271
    It's possible that if you are that close to Crystal Palace, the terrestrial TV signal could be overloading the aerial amplifier, and causing it to be insensitive to the signals from the Sky box.
  3. stuartjprice
    stuartjprice
    Even without the booster the signal is pretty bad. I'm sure I'm far enough away from the mast - atleast 8 miles as the crow flies.
    I can only think it is the quality of the cable. I've tried another ordinary tube tv and that is just as bad. Is the outer mesh of copper on a coaxial cable very important. What does this do anyway?
  4. GGTVBD
    GGTVBD
    Feb 5, 2004
    3,397
    Bradford, West Yorkshire.
    +325
    Stuart,
    Which signals are bad? All of them or just Sky? Are they OK from RF1 to your main TV?
    A. Dork
  5. stuartjprice
    stuartjprice
    Sky is just bad. I don't have RF1 connected.
  6. GGTVBD
    GGTVBD
    Feb 5, 2004
    3,397
    +325
    So the terrestrial channels are OK on the second set? Just Sky's poor?
    Unplug the TV aerial from the digibox. What happens?
    A. Dork
  7. stuartjprice
    stuartjprice
    When I do that everything goes off.
  8. chedmaster
    chedmaster
    Jan 29, 2005
    2,661
    68
    +28
    I think i used to have the same problem as this, and a local aerial man came and installed 2 signal resistors to the "aerial in" port on the digibox, as the terrestrial signals were too strong in the winter with all the leaves off the trees. One of the resistors has 6 on it and the other 3, and at different times of the year i fiddle around to get the best picture on everything. They were simple in line resistors, about 1"1/2 long
  9. stuartjprice
    stuartjprice
    Mmmm.. thanks. Not really a electrical person so wouldn't know what resistors to buy? Why isn't anything straight forward!!
  10. hog
    hog
    Jan 15, 2005
    380
    28
    +36
    hi
    if you disconnect the rf input to your sky box and leave the rf2 in place you should get a clear picture on your 2nd tv, if you dont there s a good chance you have a bad cable or connectors so you can work from there to trace it , the resistors that are mentioned are attenuators 3db ,6db etc that are used to cut down strong signals. see how you go.
  11. GGTVBD
    GGTVBD
    Feb 5, 2004
    3,397
    +325
    Stuart,
    Don't be misled - attenuators will only mask the fault, not cure it. It is staightforward for a decent engineer!
    If you pull the TV aerial INPUT to the digibox you shouldn't lose Sky.
    A. Dork
  12. stuartjprice
    stuartjprice
    OK thanks for all that advice.
    Don't know where I would be without these forums! They are so useful.
    As i don't have a lead plugged in RF in or RF1 out etc only the dish in and RF2 out, it must be cables or connectors. I will check tonight and get back tomorrow!
    Thank you all!
  13. derbyjj
    derbyjj
    Feb 16, 2005
    238
    Rainhill
    +19
    make sure you are not using a taboo channel for the rfout ie one that is being use fore terrestial or a freeview mux it wil cause the problem you describe
  14. ollieg
    ollieg
    I have the exact same problem - my second screen works fine on terrestrial with the standard aerial going into the sky box then on to the second screen. The sky picture is rubbish at this point. As soon as I take the aerial out of the sky box, the sky signal is crystal but obviously i dont have any terrestrial channels. What are these resisters and does anyone know where you can buy them from?
  15. Nick_UK
    Nick_UK
    Nov 13, 2004
    9,748
    103
    +271
    Sounds like you might need one of these
    However, before you do, try changing the channel number of your RF out on the Sky box. Press Services, 4, 0, 1, Select on the Sky remote and you will see the option. Your Sky could be being wiped out by a terrestrial channel on the same frequency.
  16. Bluevanman
    Bluevanman
    Crystal Palace transmits on Group A,ie ch21-37. Try retuning the RF2 output to something like ch44, then retune your TV and see if it makes a difference. If not suspect the cable/connections and replace them with a double screened cable.
