Bad signal! Advise please
Discussion in 'Satellite TV, Sky TV & FreeSat' started by Ukkel1, Nov 6, 2004.
  1. Ukkel1
    Ukkel1
    Hi i have a Thomson Freeview box in the loft and till recent the reception was good. Now all of a sudden, i have on all the channels a bad signal. I have tried to turn the box off and on but still i have a bad signal. What to do?
    Many thanks for any advice
    Ukkel1
  2. avanzato
    avanzato
    Jan 21, 2003
    1,954
    Norfolk
    +77
    What aerial are you using and have you checked that all the connections are still good?
  3. Ukkel1
    Ukkel1
    I will double check the connections. I have an antenna sitting in the loft, from which the FM and TV signal go to the loft. The loft has been rebuilt 3 years ago. What i do not understand is is that it worked fine till recently.
    Ukkel1
