Bad Reception
Discussion in 'General TV Discussions Forum' started by Tom Bola, Oct 22, 2004.
  1. Tom Bola
    Tom Bola
    I've recently bought a 2nd tv, and have split my aeriel cable (analogue) for theis telly.
    However, this has had a bad effact on the signal which was not too bad before and is terrible on both screens now.
    Would a signal booster cure this? :blush:
  2. Chris Muriel
    Chris Muriel
    Jun 14, 2002
    7,278
    Manchester
    +761
    A decent "active splitter" would do the job.
    Passive splitters involve half of the signal that you started with going to each TV.
    Chris Muriel, Manchester.
  3. mjcairney
    mjcairney
    Oct 26, 2003
    7,193
    2
    2
    137
    Airdrie, Scotland
    +1,006
    Remember, if you amplify a bad signal, all you'll get is an "amplified bad signal" if you see what I mean.
    You may be better off with a second aerial for the second TV.
    Cheers,
    Martin.
  4. Tight Git
    Tight Git
    Mar 3, 2004
    6,331
    +597
    If by "split the cable" you mean you've just cut it and twisted the ends together, this is asking for trouble even in a high signal strength area.
    (You'll get an impedance mis-match which will cause reflections on vision and corruption on Teletext.)
    You must use a proper 75 Ohm splitter, either active or passive. :lesson:
    Hope this helps
  5. scrapbook
    scrapbook
    Jan 12, 2002
    7,435
    +553
    Where is your aerial? If it is in the loft or easily accesible then get your self an aerial amplifier. Works wonders!
