Bad quality after converting to MPEG2
Discussion in 'Camcorders, Action Cams & Video Editing Forum' started by stevebb, Jun 27, 2003.
  1. stevebb
    stevebb
    Dec 13, 2002
    1,155
    Ashby de la Zouch
    +58
    Ive recently bought a sony trv60, pinoeer dvdr106, pinnacle studio and tmpgenc.
    I can capture the video perfectly to avi and the quality is excellent. I then use tmpengc to convert to mpeg2 and the quality is very poor. I was under the impression that tmpengc was the best at converting avi to mpeg2?
    Is there a standard set of options i need to use?
    Im recording in 16:9 mode on the camcorder and converting in the same format.
    Steve
  2. JefUK
    JefUK
    Mar 31, 2002
    440
    28
    +52
    Are you capturing to a DV-AVI?
    The quality from TMPGEnc will easilly exceed commercial digital TV or DVD encoding, provided the right settings are used. If you send me a private message with your e-mail address I will send the templates that I use.
    Have you got the aspect ratio settings correct? I am not familiar with trv60, but does it capture as a 16:9 frame or as a 16:9 image in a 16:9 frame? In which case use the 4:3 aspect ratio and let the display sort out the displayed aspect ratio.
  3. David
    David
    Nov 26, 2002
    221
    16
    London
  4. vonhosen
    vonhosen
    Jan 6, 2003
    1,835
    41
    London
    +13
    Rui's Guide is very good source of info for settings in TMPGEnc.
    TRV60 does not have a 16:9 CCD so you are throwing away 25% of your resoltuion by recording in that mode (unless you are using an anamorphic lens , which would cost more than the camera)
    IMHO TMPGEnc is not THE BEST encoder but it certainly is one of the best value for money quality encoders, even if it is slow.
