Bad picture on plasma through 10 DVI
Discussion in 'Cables & Switches' started by skinleverton, Jan 9, 2005.
  1. skinleverton
    skinleverton
    Am trying to link my pc to plasma with painful results.
    have v good spec on pc and the g/card has duel DVI output (xfx6800geforce)
    but the picture has very few colours and very patchy the cable is a 10 m DVI
    which i suspect is part of the problem. Can the signal be boosted or do i just pay for a high quality DVI to sort this out? any help would be greatly appresieated.
    SKIN :confused:
  2. docjan_uk
    docjan_uk
    Aug 20, 2004
    82
    Cheap DVi cables are fine for short runs, however for longer lengths you'll experience problems such as sparklies as data is lost/corrupted and there isnt error correction as far as I am aware.
    You'll probably have to spring for a better cable... however Im not sure you should be experiencing SUCH loss in quality...
