Bad picture on 32" TV from GameCube
Discussion in 'General Video Gaming Chat' started by Niburu, Oct 13, 2004.
  1. Niburu
    Niburu
    Hello all.
    I have just joined this forum and hope that someone can help me with a small problem.
    I have recently bought a Philips 32" 100hz widescreen TV and have connected it up to my GameCube via the normal Scart cable that comes with the cube. I am finding digital interference on games, especially Mario Kart in 60hz mode, mainly diagonal lines through some of the colours that severely intefer with the screen. Is this a limitation of the GameCube or would the RGB scart cable available help with this problem.
    Has anyone else had the same thing and managed to cure it?
    Thanks in advance.
  2. zantarous
    zantarous
    Dec 11, 2002
    1,026
    63
    +151
    Throw away that cable you are using as it is useless and get a propper Nindtendo RGB cable you will find that improves the picture loads and make sure it is the Nintendo branded one as some of the third party ones don't work very well.
  3. JUS
    JUS
    Jan 21, 2003
    3,179
    Plute
    +221
    I agree..Official RGB scart is great..very clear and crisp picture :)
  4. Niburu
    Niburu
    Well, thanks zantarous and JUS for the advice.
    I have just this minute ordered the official NINTENDO scart cable!!!
    I hope it cures most of my woes.
  5. CAS FAN
    CAS FAN
    Nov 24, 2003
    34,798
    167
    The Wheldon Road end!
    +7,962
    I recently bought a brand new unofficial RGB lead off ebay for £4 including postage and it's superb. Amazingly crisp picture! :thumbsup:
  6. Rob20
    Rob20
    Jul 3, 2004
    2,619
    103
    +354
    I use an official Nintendo RGB scart on my 26" Tosh lcd and the PQ is great. Picked it up 2nd hand for £10. :)
  7. mr_fantazmo
    mr_fantazmo
    The game one is pants!! :thumbsdow Avoid avoid avoid!! I got a cable modded from an official Nintendo Digital Video cable and it's the SHIZNIT!!
    MMMMM Crystal clear Biohazard 4!!
    The only problem with the Nintendo Scart is the lack of phono outputs for Prologic 2!! DOH!! :nono:
  8. Pooon
    Pooon
    Dec 26, 2002
    7,127
    Canterbury, Kent
    +731
    Has the Philips Tv got the Pixel Plus feature? If so have you tried it without it turned on?. But whatever the case the Offical RGB Scart is still an essential purchase.
  9. Niburu
    Niburu
    Hi there.
    Just thought I would let everyone know the result of getting the Nintendo RGB scart cable. What a difference!!!!! All the digital interference has gone and the picture is superb, so good in fact, I couldn't stop grinning for about 2 hours!! I still have a smile on my face.....
    I recommend anyone with a cube to get a better cable!
  10. oliver24
    oliver24
    How about Svieo is this possable on the Cube?
    Would like to use the Svideo input on the front
    of my Yamaha AV amp
  11. Niburu
    Niburu
    Hi.
    I don't believe there is an Svideo cable available for the Cube, although in theory, you could probably make one! The decent cable needed for the GameCube is a Scart only.
  12. RL123
    RL123
    Nov 4, 2002
    1,037
    38
    +4
    S-video output was disabled for PAL Cubes. It was in the US/Japan versions but they didn't have RGB. So Europe got RGB instead of S-video - fair compromise if you ask me :D
  13. oliver24
    oliver24
    Ok, I was thinking of Svideo as that would of allowed me to go from my
    Yamaha into my Iscan Ultra, I dont really want to spend £120 for
    a js rgb to component converter,
    So the question is is it worth going to the hasle of using my Isacn Ultra
    or may I as well just go stright to the tv with Nintendo RGB cable
    Infact am I being dim here do the make a Gamecube to component
    video cable if so then I can go into the 2nd free componet input
    on the Isacn and make it all prog scan i think.
  14. hornydragon
    hornydragon
    Dec 19, 2001
    28,293
    +1,215
    Yes you can get component cable for GC i think it needs to use the digital output (would the digital output not work better????) Try www.lik-sang.com for ideas of cables
  15. RL123
    RL123
    Nov 4, 2002
    1,037
    38
    +4
    Yes it uses the Digital Output but iirc it only outputs video, so you will need to use a composite cable in the analogue port to get sound
  16. hornydragon
    hornydragon
    Dec 19, 2001
    28,293
    +1,215
    Yeah it is a video only connection from the digital port...... What digital signal is it anyway????
