Bad DVD-Rs : why are the errors on the outer edge? (& a work-around!)
Discussion in 'Blu-ray & DVD Players & Recorders' started by TP2K, Nov 14, 2003.
  1. TP2K
    TP2K
    Nov 14, 2002
    523
    16
    Something that has baffled me for a while... why is it with bad DVD-R media, that breakup always occurs during the last, say, 30 minutes of recording (as the data gets close to the outer edge)?
    Funny thing is, the recording can utilise the whole disc, or just half the disc, but if the disc is a baddie then the error still occurs at the ending of the recording! :mad:
    If anyone does suffer this problem (I know we're all aware of it and pretty much avoid certain discs now, but I have a lot of stuff from the "early days"!) here's a brilliant tip;
    If you have discs which have break-up near the end, simply "fast forwarding" the entire disc - then play it, you shuold find it plays perfectly OK!
    Don't ask why... but it does!
  2. CARLOS
    CARLOS
    Feb 11, 2001
    5,928
    WEST MIDLANDS
    +1,208
    I`m sure i read somewhere its due to that when they print the discs the dye is thinner towards the edge ?
