flat spot
Established Member
After only just reading about this film I've decided to buy it. Little did I know the minefield which lay ahead.
There seem to be numerous versions. Cut,uncut different covers on the box etc etc.
I'm going to ask in the wanted section 1st so need to get it right. I'm after the uncut version although any region will do (not blu ray).
My real confusion lies in the price. In the uncut versions they can be around £13 Amazon (although someone has asked if even this one is a little shorter than it should be) or £30 at Play.com with not much inbetween.
Can anyone shed any light on which is the true uncut version and which cover it should have on it?
Cheers F.S.
Cheers F.S.
