thepharcyde
Established Member
I used to have a image file of my old HTPC based on MCE2005 using Norton Ghost. My version is no longer supported in Vista.
What software is out there that you recommend. I basically want to put a CD in the drive which will then pull the backup from one of my backup hardrives incase I am unable to get into the Windows environment to restore that way
Thank you
Thank you
