Question Backup embedded XP using USB and external HD
Discussion in 'Computer Software & Operating Systems' started by zillah, Sep 1, 2018.
  1. zillah
    zillah
    Mar 25, 2005
    16
    Dear Expert
    The picture below for a computer box that has embedded XP that is used for with wood cutting machine.
    Imgur
    Machine similar (not same) to this :
    Buy Woodtech Machinery Combined Planner WT 101 at discount rate online in india | Woodzon
    Last week OS XP stuffed up and we had to wait one week to be fixed
    Now it is working fine
    What a backup program (run from USB) can I use to create an image for the existing OS to be restored in case of emergency
    I prefer to use a rescue USB and external hard drive to store backuped image ??
    Thx
  2. MarkE19
    MarkE19
    Aug 10, 2002
    17,508
    Rainham Essex
    +2,511
    Acronis True Image or Norton Ghost will both create a full disk image, just make sure you get a copy that works with XP if you want to install it but many versions can run from a bootable drive.
    Mark.
  3. zillah
    zillah
    Mar 25, 2005
    16
    Thanks for your help
