Backing up of Laptop
Discussion in 'Desktop & Laptop Computers Forum' started by luke0380, Feb 5, 2009.
  1. luke0380
    luke0380
    May 3, 2006
    280
    Backing Up Laptops
    Hello
    Some people may have been in the same boat as me so i would welcome so help or recommendation.
    I am looking for backup solution for users with remote laptops. At present they don't backup, so all their documents and emails are exposed to being lost if their hard drive goes wrong . The emails are download via pop3 (cannot change this at present) so once downloaded from they are at risk.
    I am looking for a solution that backs up to an external hard drive. As the responsbilty falls on the user to back their laptop up, it needs to be simple and easy to use but robust enough not to fail. Even something like press one button and the job runs
    At present i am not concerned about backing up the entire laptop , but the Documents and Outlook (2003/2007)
    The only other requirements is Password Protection and Encyption.
    I am aware of Online backups but at the moment this is not required.
  2. FireKracker
    FireKracker
    Jan 10, 2008
    630
    Derbyshire
    +98
    If you're just after backing up Outlook mail try here. As for backing up 'my documents' have a look at Cobian Backup a free utility that has many features including auto backup facility + its free. BTW I use this myself. :)
    Hope that helps!
  3. luke0380
    luke0380
    May 3, 2006
    280
    Anyone else ???
  4. WHUFC
    WHUFC
    Dec 14, 2008
    374
    MAnchester
    +69
    old school ntbackup.exe start/run.
    will do backups restores scheduled password encryption backup to any location and its free and installed as default on any os.
  5. Mr Lazy
    Mr Lazy
    Jan 14, 2008
    1,026
    Rochester, Kent
    +144
