backing up dvd collection
Discussion in 'PC Gaming & Rigs' started by BrynTeg, Sep 2, 2004.
  1. BrynTeg
    BrynTeg
    Sep 9, 2000
    15,094
    137
    Cardigan Wales
    +1,952
    just a quick question,if your dvd rom is set to region2 and you want to backup,burn,decrypt a region one dvd,should it work,mine only seems to like r2 now,every r1 burn process fails? :cool:
  2. H4r7y
    H4r7y
    Jun 17, 2003
    1,713
    39
    Nottingham
    ive done a few backups, mainly region 2 stuff though. i did try to do a region 1 disc though recently and windows asked me if i wanted to change the region of my pc, but it did say i only 2 changes left?! i dunno what it meant but i kept it region 2 anyways.
    but why would you want to keep the region? wouldnt you prefer to make it region free? so youd be able to play on r2 players etc?
  3. BrynTeg
    BrynTeg
    Sep 9, 2000
    15,094
    137
    Cardigan Wales
    +1,952
    the problem i have is that the dvd rom drive is permanently set to region2 so i think it has problems backing up a region one.
  4. Hawklord
    Hawklord
    Feb 15, 2003
    3,558
    4
    Aldershot, Hampshire
    +304
    I usually use dvdshrink to back up my dvd's but that only usually allows you to back up either region 0 or the region specific to your dvd drive. To overcome this I use dvd decrypter which removes all the region encoding and allows me to copy to my hard drive. I then use dvdshrink to burn to disc from the hard drive file I have just created. Takes about 15 mins longer but it works for me :) You could alternatively find a firmware hack for your dvd drive to make it region free.
  5. BrynTeg
    BrynTeg
    Sep 9, 2000
    15,094
    137
    Cardigan Wales
    +1,952
    hawklord i use the exact same system as you,first of all dvd dycrypter into a certain file,then dvd shrink which leads to the burning phase,it encodes the whole dvd which you see it a little box with a scrolling bar which says how much time is left,its once it goes to burning phase that the whole thing fails on region 1 discs,mjust be because its set to region 2 on the dvd rom.
  6. Hawklord
    Hawklord
    Feb 15, 2003
    3,558
    4
    +304
    If the file on your har drive is decrypted it shouldn't matter what region your drive is :confused:
    I have no issues backing up any region atall using the method I have decribed.
    I'd make sure you've got the latest version and try again:)
  7. BrynTeg
    BrynTeg
    Sep 9, 2000
    15,094
    137
    Cardigan Wales
    +1,952
    its strange,i thought it wouldnt matter,it used to burn all regions,but now as soon as it burns the lead in phase it fails,and only with r1????very wierd.i use dvd decrypter and dvd shrink 3.1,is there a newer dvd shrink?
  8. Hawklord
    Hawklord
    Feb 15, 2003
    3,558
    4
    +304
    my dvd decrypter is version 3.5 and dvdshrink is 3.1 :D
  9. drummerjohn
    drummerjohn
    Sep 2, 2001
    2,494
    South Derbyshire
    +203
    Use AnyDVD in the ripping process and you wont have a problem. You need to both remove the region encryption when ripping and burning - which AnyDVD does.
  10. BrynTeg
    BrynTeg
    Sep 9, 2000
    15,094
    137
    Cardigan Wales
    +1,952
    where can i get anydvd from,
  11. drummerjohn
    drummerjohn
    Sep 2, 2001
    2,494
    South Derbyshire
    +203
  12. BrynTeg
    BrynTeg
    Sep 9, 2000
    15,094
    137
    Cardigan Wales
    +1,952
    ahh,but its quite expensive...the free version only last 20 days
  13. Hawklord
    Hawklord
    Feb 15, 2003
    3,558
    4
    +304
    What's the make and model of your drive . I'm sure there will be a firmware hack to make it region free somewhere:)
  14. BrynTeg
    BrynTeg
    Sep 9, 2000
    15,094
    137
    Cardigan Wales
    +1,952
    i,ll have to check it out,its not branded on the front panel.
  15. drummerjohn
    drummerjohn
    Sep 2, 2001
    2,494
    South Derbyshire
    +203
    £23 expensive? Trust me, its worth every penny.
    Ive tried DVDRegionFree, Region Killer, DVDGenie, Remote Selector - none of these I have found to be as efficient and bug free as AnyDVD.
  16. CENSORED
    CENSORED
    Smartripper to decrypt and rip. DVD2One to re-encode, Nero to burn. Works without fail every time.
  17. Indiana Jones
    Indiana Jones
    Nov 4, 2003
    35,760
    Bristol
    +8,883
    The problem is that your DVD drive is locked to Region 2 so you cant playback or decrypt anything but Region 0/2, trust me I have been burning DVDs for nearly 2 years and have come across this problem more than once.
    To get around this either install and run DVD Region Free which will allow you to playback and decrypt any DVD no matter the Region, or set your DVD Writer to Region 1 and your DVD Rom to Region 2 so you will have a drive for each Region, this way you wont use up the Region changes on either drive and will be able to rip easily. The last thing would be to get a firmware hack for your dvd-rom drive which would make it Region Free but this can go wrong and if it does you will be left with a duff drive.
