Backing up Discs
Discussion in 'Blu-ray & DVD Players & Recorders' started by wharfman, Nov 20, 2004.
  1. wharfman
    wharfman
    I have a question about backing up discs onto thE HDD (for arguments sake lets say the Pioneer 420- my fav at the moment to purchase soon)
    Are all elements of the dvd copied? commentaries , subtitles etc if there are any?
  2. Benfica
    Benfica
    In Pioneer recorders the backup disc function allows you to make a copy (bit x bit) of a DVD-R(W).
    You first copy it to HDD and then you copy it again to a blank DVD-R(W).
    So, everything is copied.
    You don't have any access at all to that content while it is in the HDD.
    Hope that helps
  3. ernet
    ernet
    Moreover you are asked to save the copy on HDD or not
  4. dicky
    dicky
    Apr 8, 2004
    165
    Cambs
    Sounds to me like you are wanting to backup a commercial DVD. To answer your question you won't be able to backup a commercial DVD to the HD, however there are ways round this.
    When you find the ways round this :D it will back up the film to the HD but not the extras or commentaries etc
    Regards
  5. Bosco
    Bosco
    For the extras you will need a PC and also will need to be the legal owner of the commercial DVD.
