Backing up difficult cd's ...
Discussion in 'Desktop & Laptop Computers Forum' started by lynx, Apr 6, 2003.
  1. lynx
    lynx
    Jan 20, 2002
    4,651
    It always rains.
    +302
    I have had extreme difficulty backing up one particular cd, Easy cd creator, nero and some specialised software failed to do it, but good old XP Pro has delivered the goods.
    If you have XP PRO try this where nero, cd creator and the rest have failed!
    Place original cd in drive , then a blank one in your CD re-writer.
    Now goto MY COMPUTER,click on the drive with the original cd in.
    NOW DRAG AND DROP INTO THE CD-REWRITER DRIVE.
    Windows now makes a temp folder for that drive only
    right click and pick COPY TO CD
    you will now have a perfect copy of the original cd which Nero, ecdc etc wouldn't copy.
    :smashin: :)
  2. nathan_silly
    nathan_silly
    Clone CD
    CDRwin/Golden Hawk
    Both are much better at copying CD's with copy protection/funny layout.
  3. lynx
    lynx
    Jan 20, 2002
    4,651
    It always rains.
    +302
    None of them worked.
    Than what ? Have you tried the method i suggested ?
  4. nathan_silly
    nathan_silly
    Easy CD Creator.
    My drive is a SCSI, which has better software support. Never tried your way- Clone CD/CDRwin makes a bit for bit copy- as long as the drive is fully supported.
  5. lynx
    lynx
    Jan 20, 2002
    4,651
    It always rains.
    +302
    Clone cd, & others ( which i was refering to as 'specialised software ') were unable to return a working backup.
    The above method has not failed me yet ( although i'm not suggesting it's perfect ).
