Back up on "C" drive
webbonline
Hi again i got a massive back up of my complete system on the "C" drive its slowing everything down but i cant delete it Grrrr ....... help lol
warning say's
Can not delete amd64: access is denied
make sure the disk is not full or write protected and the file is not currently in use ??????
my disk could be full as this file is massive over 200 GB but what do u do then ?
i saved this file when i did a recovery but the saved file is making things worse than before Grrr
any help welcome :) Webb
MarkE19
I would guess that at over 200Gb the file is too big for the Recycle Bin. Try holding down the Shift key when deleting the file. This will delete the file rather than just moving it to the recycle bin.
Mark.
webbonline
Hi Mark thanks for the reply i just tried to delete while holding shift it seem to work at first but then put a box up saying can not delete file
Webb
mossym
is the backup software still running? if so it may have the file locked so you can't delete it
MarkE19
Is you account in Windows a full admin account? If not then log into an account that is and try to delete it.
Get a boot CD and try and delete the file once booted from that.
Mark.
try right clicking on the folder and selecting properties. Then select SHARING tab. Then make the folder private. Maybe its been setup as a shared folder ?
webbonline
not sure how would i know ???? when i used the recovery CD it asked me if i wanted to save a copy of my entire system etc i said yes, as it, recommended it ..... the file is read only and a option to make it hidden ??? in the advance option u can archive it but when i tried it said 3 days 10 hours to completion lol
webbonline
cant delete from CD i can reinstall with out saving but i got my system real good just wont that file gone surely there must be a way ? in running out of space like mad lol
webbonline
Hi again and thanks Maddogb that free unlocker program did the trick its a bit complicated to use and i had to restart a few times but finally i got rid of my back up and things are a lot faster and smooth again :smashin:
