Back Plate Question - Multi Sat
molokoid
Hi, i've been searching everywhere for a plate or combination of back plates that would suit what i'm after for a pending installation...
Sky HD install, with two mirrored sites around the house means four Sky cables coming through the wall. That plus my coax means i was after the following, but after it in some sort of flat brushed/satin steel or chrome...
Plate A - 2 sat, 1 coax
Plate B - 2 sat
Can anyone direct me to a retailer that would have this combo please? single sat combo's seem popular, but not dual sat ones!
TIA
logiciel
mattclarkie
Can you not run the 2 sat coax and 1 TV coax to separate plates?
Or get a modular wallplate?
Would this be any good for the 2 x sat and 1 x TV?
logiciel
i can find plenty that don't fit the requirement
:confused:
One requirement is for "2 sat" - there are dozens of those on the link.
The other is for "2 sat, 1 coax" and although "sat" IS coax I assume by coax you mean TV aerial which is what mc is linking.
:confused:
mattclarkie
I don't think the one I linked will work because of the 'triplex' thing (you'd need to add a diplexer), so using a separate plate for the TV, or finding a 3/4 plate with adapters to convert F-connectors is probably best.
logiciel
Yes, there's no indication that OP wants triplexing, but my first link would have found plenty like those nexxia, and so would the location where you found yours.
