A simple question from the clueless
I have a dedicated A/V room in prep at the the mo which when finished will be aprox 7.5' x 15'
My speakers are a combination of B&W Nautilus 800 & Signature series. I still need the sub to finish it all off though. Question is, should I go for an ASW 855 or will it be too much for such a relatively small room and should I therefore go for the 825 instead? If so is there much of a drop in quality or is it just about clout?!?
Any advice would be appreciated
Cheers,
Jester
Cheers,
Jester
