B&W speakers
Discussion in 'Home Cinema Speakers' started by figlio, Apr 8, 2003.
  1. figlio
    figlio
    Dec 17, 2002
    179
    Malta
    Hi to all,
    I have a B&W 600 S2 system. These are 603 (fronts) LCR6 (center) 601 Rears. ASW1000 subwoofer.I am thinking to buy the
    604 S3 for fronts and another subwoofer the asw 675. I am going to use the 603 as rears and the 601 as fron effects and the
    old subwoofer with the front speakers. Is this system is going to work good or there is difference between series 2 and series 3
    Best Regards
  2. sounddog
    sounddog
    Dec 11, 2002
    3,370
    107
    Leicestershire, UK
    +461
    Not a huge difference ... though the 601s3 are better than 601s2 and 602s2 are better than 602s3 - based on a dealer comments when they weren't going to get a sale whatever they said ... was just in discussion!!
