B&W speakers
Discussion in 'AV Receivers & Amplifiers' started by steve k, May 12, 2001.
  1. steve k
    steve k
    Apr 15, 2001
    709
    Birmingham
    +53
    Can Anyone give me sum idea how much the CDM 9NT, CDM surronds & center, would cost :confused:
    I can't find any prices in the mags to compare prices.
    Thanks for your help
    Steve ;)
  2. Guest
    Just put the speaker name/designation into a search engine and you should get a result. I found cdm snt last night for £750 new on one site and a pair of second hand ones with 12 months guarantee for £525 (that was on www.lintone.co.uk.). Check out the adverts in the mags for hi-fi shops who stock B&W and have web sites
  3. compusolve
    compusolve
    Steve
    re CDM9NT's I paid £1900 pound for mine from Sevenoaks, I am not sure of the centre prices at a guess I would imagine 400 + as I have the HTM Matrix older but similar at £500 +
    Hope this helps
    Garry
