Bargain B&W PV1D subwoofer £799 at Sevenoaks
fatboy frank
More stores have them too.
Personally there are a few other sub's i'd rather spend £799 on, it's still £500 over priced!
Ed Gayton
Care to suggest some? I might be in the market for a new one and would value any recommendations. Be good if it looked nice too to keep the wife happy.😉
Conrad
For £799, any of the BK subs, the smaller SVS, that's where I'd start.
fatboy frank
As @Conrad. has already mentioned, any of the BK Subs B.K. Electronics Homepage
I'm actually considering getting a Double Gem for my music setup in the bedroom.
Gasp3621
Depending how small you looking SVS 3000 Micro would be good step up from the "bowling ball" and has better warranty/support etc. We have had few members cursing with the B&W after amp dieing. SVS SB1000 also at 500£ mark if you get AVF member discount. I believe it`s the smallest woofer in the market that has 12" driver and comes in three finishes to keep wife happy. Plenty of choices depending the critical dimensions/finish/what you looking from it..
As Conrad mentioned BK is good option if you want something small in real wood veneer finish, perhaps the DF model so the driver isn´t visible. Like a small furniture and cheap.
bazkav
I always coveted the PV1 D back when I had a ASW 650 then two of them.
Then i replaced them both with the SVS PB 2000 Pro and I was blown away it might not be a looker but it is mighty.
Podcast: LG C1 OLED + JBL Synthesis SDR-35 First Thoughts, plus TV Show & Disc Reviews & more
