I'm using a Gforce 4 TI 4200 graphics card connected to the tv using the svideo connection and can only get a B/W image. Ive gone through all the settings including obviously setting it to PAL UK. When connected to my ae100 pj using the nomal monitor connection everything is fine. Any suggestions would be appreciated
S-video is Y/C (Luminance and Chrominance) sent on separate wires. You appear to only have the "Y" part. On the TV, you may have to press its A/V or video-source select button twice to get the TV in s-video mode ; the TV's OSD (on screen display) should confirm whether or not you have it in s-video mode. If it is in s-video mode, you can only have either a faulty lead or something incorrect in the card setup. Your s-video lead needs to be the correct one in that some have a "direction-switch" ; if you have a male-to-male lead try turning it round - putting the end currently at the TV into the card & vice-versa. Chris Muriel, Manchester
Its definately not the lead as Ive used it via a dvd player through the front svideo on the front of the tv and it works fine The most logical thing for me to do of course would be to run the svideo lead through the projector to find out if the problem is with the tv or video card
I've got a GF4 MX440 card, and that seems only to put out in B/W as well ?? I never did find out what the problem was, as i'm now using the VGA out instead. I did have an S-video / phono adapter and that worked ok via comp.video ?? keelby1: Have you tried the TV-Tool utility ?? Maybe that'll make a difference ?? Cheers Cosmic023
