B&W P5's - Any good?
Discussion in 'Home Cinema Speakers' started by doug62, Oct 3, 2004.
  1. doug62
    doug62
    Oct 3, 2004
    53
    I have recently won an auction for some B&W P5's which i bought spare of the moment and without really researching them(i'm a bit daft like that sometimes).
    The thing is i dont seem to be able to find much in the way of reveiws so i wondered if anyone knew much about them and also could recomend an amp that would get the best out of them?
    cheers folks
    Doug
  2. SKA.face
    SKA.face
    I have some P6 at home,I wouldn't say they are exellent,but they are good,I found the treble was way too shrill,they are a bit lean,a touch thin,but have nice scale,powerful sound and fairly good imaging,it's a shame the treble is so aggresive,but they look great,mine are rosewood,I would recommend the older 800 matrix over the P range as the matrix are superb.very musical,miles better treble,natural, a much better speaker,I think you'll be happy with the P5 though,similar in sound to the CDM range.
  3. doug62
    doug62
    Oct 3, 2004
    53
    Cheers SKA,thats put my mind at rest a bit,i'm actually going to pick em up tmorrow so i guess its too late to change my mind but i'm sure they'll be fine!i paid £280 for em,and you dont get much speaker at all for that money these days! :thumbsup:
  4. SKA.face
    SKA.face
    At £280 that's a steal they were about £900 new,they do look good,better than a 603.I think you'll like them,they are good,just watch out for the treble a bit though,good luck!!
