b&w original 602's shielded or not??
Discussion in 'Home Cinema Speakers' started by kiddi, Nov 21, 2003.
  1. kiddi
    kiddi
    anybody know if the original 602's are magnetically shielded or not? I have them pretty close to the TV as it is??
    Worried it might damage the tv if they are not shielded..
    Anybody help me?
  2. Crustyloafer
    Crustyloafer
    Sep 12, 2003
    9,522
    Edinburgh
    +1,241
    The current version of the 602's are not shielded so I would almost definitely assume that the older ones are not either. B&W recommend a distance of at least 0.5m between each speaker and your television.
  3. kiddi
    kiddi
    thanks for the reply. if 0.5 is enough, then I'm safe...
  4. SKA.face
    SKA.face
    The original 600 series were NOT shielded.HTH.
  5. kiddi
    kiddi
    0.5 meters away from the tv should be enough then?
    can it permanetly damage the tv? or is it simply interference that disapears when there is enough distance.
  6. Gomez
    Gomez
    IMO, 0,5m is definitely not enough. But that also depends on your TV and how sensitive it is regarding magnetic interferences.
    My 602 S3 are about 1m away form my TV and still cause a greenish triangle in the left upper corner of the TV.
    Normally, the interference disappears when you move away the speakers. But sometimes, it's that strong that it can cause a permanent error in your TV's tube.
  7. OllyH
    OllyH
    Nov 10, 2003
    238
    +12
    I find that 0.5m is fine (Sony 32" widescreen). Any less and you notice colour distortion.
  8. kiddi
    kiddi
    Thanks alot for all the responses. I've moved the speakers about a meter away from the tv now. Never did see any green colour or distorition before thought. Better to be on the safe side though!
    Again,
    Thanks for the help. This forum is a gem.
