B&W or Mission??..
Discussion in 'Home Cinema Speakers' started by andy76, Aug 9, 2002.
  1. andy76
    andy76
    Not sure what to do about speakers.
    I have a Rotel stereo amp and B&W 602s.
    I am going to buy a multi channel amp and either link it to the Rotel and use the B&Ws plus extras, or keep it as a seperate system and buy a Mission FS2 AV package.
    What would you recommend?
    The system is in my bedroom which is about 4.5m square with usual bedroom furniture in it.
    I think the Missions are easier to install in terms of rear installation but know the B&Ws are good for bass on movies.
    If I go the B&W route what should I use to partner them?
    Obvious choice for centre is the LCR60 but for rears?
    Another set of 602s or the smaller 601s?
    Andrew
    PS please see my other Q's in relevant forums.
