B&W Nautilus - anyone upgraded the phase plug's ?
Discussion in 'Home Cinema Speakers' started by Boozyuzi, Sep 23, 2004.
  1. Boozyuzi
    Boozyuzi
    Aug 10, 2002
    531
    Edinburgh
    +35
    Has anyone upgraded the plastic phase plug's on their Nautilus speakers for a pair of aluminium or copper ones similar to the phase plugs used in the signature speakers ? I've got a pair of standard 805's and I am interested to find out if it's a worthwhile cheapish upgrade.
  2. JurgenNL
    JurgenNL
    Jun 12, 2002
    282
    +20
    No one???
    I would like to know if it improves the sound, too.
    Jürgen
  3. Boozyuzi
    Boozyuzi
    Aug 10, 2002
    531
    Edinburgh
    +35
    I've just ordered a pair of official B&W Nautilus signature phase plugs to replace the plastic ones that come with the standard 805's. I shall let you know the differance they make when they arrive.
  4. inzaman
    inzaman
    Dec 16, 2002
    7,942
    Derby
    +1,020
    Did these make a difference at all to your B&Ws, or has anybody else changed their's?, if so is there any improvement.
  5. Pat Marcus
    Pat Marcus
    Oct 29, 2004
    610
    Ibstock
    +8
    Yep - ive changed the phase plugs on my 804s on the advice of another forum member. I have to admit that B&W were a little reluctant to supply them but gave in when I reminded them about all the product Id bought. Ive noticed that the new 800 range come with heavyweight metal phase plugs as standard.
    Does it make a difference ? Small but worth having - adds a little more "naturalness" to the sound. I wouldnt go back and I will be slowly upgrading the phase plugs on the 5 others in the system. For about £35 per pair, its worth doing.
  6. inzaman
    inzaman
    Dec 16, 2002
    7,942
    Derby
    +1,020
    Thanks for the reply, i think i will try some, i want it for my HTM1 centre as that is the only 800 series speaker i have. This will soon be rectified though once i find some exdem or second hand 804's.
  7. bass007
    bass007
    Apr 8, 2004
    1,291
    london
    +35
    is it easy to change them? if so how? would I be able to change the ones on the CDM1Nt's
  8. Pat Marcus
    Pat Marcus
    Oct 29, 2004
    610
    Ibstock
    +8
    Its very easy on the 800 series. Must take all of about 5 seconds per speaker. unscrew. remove. screw in. sit back. smile.
    not sure about the CDM series.
  9. bass007
    bass007
    Apr 8, 2004
    1,291
    london
    +35
    Hmm, if anyone knows how pls let me know, thanx
  10. inzaman
    inzaman
    Dec 16, 2002
    7,942
    Derby
    +1,020
    I have also seen some gold phase plugs on other websites that look pretty cool, dont know what they sound like though.
