B&W Nautilus 802
Discussion in 'Home Cinema Speakers' started by Crustyloafer, Aug 18, 2004.
  1. Crustyloafer
    Crustyloafer
    Sep 12, 2003
    9,566
    Edinburgh
    +1,266
    I am in the process of selling my Acoustic Energy AE1 Mk3 speakers. I have put links to the relevant classifieds below.
    Anyway my main question is has anybody listened to the B&W Nautilus 802s and if you have what did you think about them? They will be initially amplified with my Musical Fidelity A308 integrated and my main source is the Arcam CD33, although I do play a lot of DVD-A on the Arcam DV89 also. If you have or haven't listened to them can you recommend any other speakers worth auditioning? I will have about up to £6000 retail price to spend on them.
    Acoustic Energy AE1 Mk3 for Sale
  2. Gordon @ Convergent AV
    Jul 13, 2000
    14,209
    +3,045
    I've instaled quite a few sets and thought them superb. The lowest spec amp I used with one lot was a Denon AV1SE and even that was miles better than I thought it would be. Not familier with your amplifier or CD so can't comment. Great speakers though.
    Gordon
  3. Plump
    Plump
    Feb 22, 2002
    638
    19
    under the bridge
    If you can afford them, it is no brainer.
    However audition and comparison to simmilar priced speakers can bring you even more. Try Utopias Be (or Electra Be) if you can.
